Need advice on iPad Pro 12.9 case
Dropped my iPad Pro 12.9 and damaged the case. Looking for recommendations on a durable replacement. Any suggestions?
Ouch, dropping the iPad Pro 12.9? That’s gotta hurt. If you’re looking for something durable, I’d recommend the OtterBox Defender Series. These cases are built like tanks and can take a beating. They’ve got this multi-layer design with a built-in screen protector and port covers, so it’s pretty much protected from all angles. Another option is the ZUGU case, which is super durable and has this secure magnetic stand—it’s really convenient for different viewing angles.
For those who want to avoid bulky cases, the ESR Air Armor case might be a good compromise. It offers solid protection and isn’t as heavy as other robust cases. But seriously, if you’ve already dropped your iPad once, might be worth going with something a bit more heavy-duty like the OtterBox or SUPCASE Unicorn Beetle Pro.
I’ve been using the SUPCASE Unicorn Beetle Pro for my own iPad, and it’s survived a few nasty falls without any damage. It’s rugged and offers full-body protection. Plus, it even comes with a built-in screen protector and a kickstand, which is useful if you watch a lot of videos or do some sketching.
If you fancy some style without compromising too much on protection, the Logitech Combo Touch is pretty good—especially if you type a lot or need a keyboard. Just don’t expect it to survive extreme drops like the OtterBox or SUPCASE.
All in all, choosing the right case comes down to how much protection you need versus how much bulk you’re willing to tolerate. For maximum protection, check out OtterBox Defender Series or SUPCASE Unicorn Beetle Pro. For a balance of style and protection, you might go with the Logitech Combo Touch. Happy hunting!
I’ll have to disagree slightly with Jeff on this one. While OtterBox Defender Series is undeniably robust, it tends to add significant bulk and weight. If portability is a key factor for you, you might want to explore the UAG Metropolis Series. It strikes a great balance between protection and usability. This case has a feather-light construction yet offers military-grade drop protection. The tactile buttons and adequate port access are also a plus.
Also, considering your iPad Pro 12.9 is likely for more than just casual use, have you thought about the Pitaka Magnetic Case? It’s super sleek and uses aramid fiber—stronger than steel but light as a feather. I’ve used it, and while it lacks the built-in screen protector, its material is incredibly durable.
If you prefer full-body protection without the bulk, the Smartish Prop Tart Case is worth a look. It’s a relatively new contender but offers great protection and has an integrated kickstand, which is pretty handy for propping up during work or entertainment.
Jeff mentioned the SUPCASE Unicorn Beetle Pro, and while it’s indeed a heavy-duty option, I find the Poetic Revolution Series to be a bit more stylish without compromising on the protection front. It also includes a built-in kickstand and is slightly less bulky.
For those who enjoy the finer things without sacrificing durability, check out the ZtotopCase’s Premium Leather Series. It’s not as indestructible as the OtterBox but offers a classy look with sufficient protection for everyday use.
Remember, different cases serve different needs. If you don’t mind a bit of heft, OtterBox and SUPCASE will give you peace of mind. For style and function, Pitaka or Smartish might be more down your alley. Happy case hunting!
Dropping an iPad Pro 12.9 is seriously a bummer. @viaggiatoresolare and @jeff already gave some solid suggestions, but let’s add a bit more into the mix. For those looking for an ultra-durable case, I totally see the OtterBox Defender Series being appealing. However, moving around with a bulky case isn’t everyone’s cup of tea.
If you’re looking for military-grade protection without the excess weight, cases like the UAG Metropolis Series are worth considering. They’ve managed to strike a balance between ultra-protection and usability. On the downside, the design may be a bit too rugged for some tastes.
For someone who prefers a combination of durability and style, the Pitaka Magnetic Case is an interesting option. Its aramid fiber material is incredibly strong, but if you’re someone who tends to drop devices often, the lack of a built-in screen protector might be a deal-breaker.
Smartish Prop Tart Case is a newer contender that has been getting a lot of attention. It offers solid protection and has an integrated kickstand, which is super handy for work or entertainment. However, it might fall short against really harsh impacts compared to heavy-duty options like the OtterBox or SUPCASE Unicorn Beetle Pro.
Now, if you’re leaning towards style and functionality, the Logitech Combo Touch is quite versatile, especially if you type a lot or need a keyboard. Keep in mind, though, it won’t survive a severe drop like the more rugged cases.
For a premium feel without sacrificing too much protection, ZtotopCase’s Premium Leather Series is a great option. It offers a classy look and sufficient protection for everyday use, but it’s not the toughest out there.
Overall, consider how you use your iPad. If you’re clumsy like me, the OtterBox or SUPCASE are worth the extra bulk. For a lighter option that still provides good protection, the UAG Metropolis or Smartish Prop Tart Case could be your go-tos. And if aesthetics and lighter weight are what you’re after, Pitaka or Ztotop may be more up your alley. Each has its own pros and cons, and there’s really no one-size-fits-all answer here.
