How can I check my CPU fan speed?
Recently, my PC started overheating and I suspect the CPU fan might not be working properly. I’m trying to figure out how to check its speed to diagnose the issue. What steps should I follow or what software do I need? Looking for easy-to-follow advice.
First thing I’d recommend is making sure your BIOS can show you hardware stats, including fan speed. When you first boot up your computer, hit the key to enter BIOS (usually DEL or F2, but it can vary depending on the manufacturer). Once in the BIOS, look for a section called “Hardware Monitoring” or “PC Health Status.” That section should show you the current speeds of all fans connected to the motherboard.
If you’re more into software solutions, there are a few you can try. SpeedFan is a bit old-school but still does the job well. It reads the RPM of the CPU fan and gives you control over it. Just download it, install, and run it. The interface may seem a bit dated, but it’s super functional.
Another good one is HWMonitor by CPUID. It doesn’t let you control the speed, but it’s great for monitoring temperature and fan speed. It’s user-friendly and gives a clear readout of all your system’s vitals.
For something more integrated, you can use the software provided by your motherboard manufacturer. For example, ASUS has AI Suite and MSI has Dragon Center; these tools not only let you monitor fan speeds but also give you tuning controls and other performance stats.
Also, double-check for software bloat or unnecessary background processes. If your CPU is always running hot, maybe it’s coinciding with a heavy software load. Weirdly enough, a corrupted file or unnecessary background application could push your CPU to do more work, heating things up unnecessarily.
Don’t forget to check the physical part— make sure there’s no dust clogging the fan or heatsink. Dust can totally kill airflow which makes the fan inefficient. It’s crazy how something that simple can be the root of the problem.
Lastly, make sure the fan connector to the CPU header is firmly attached. I’ve solved similar issues before where the fan was just loose enough to stop working intermittently.
These steps should help you diagnose and hopefully fix the overheating issue.
Hey, totally agree with checking BIOS and using software like SpeedFan or HWMonitor. They’re usually my go-tos too. But lemme throw a few less conventional ideas at ya:
Visual and Auditory Checks:
Even before diving into software, do a quick eyeball and listen test. When you boot up your system, pop the side panel and actually look at the fan. Is it spinning up when you power on? Any unusual noises like clicking or grinding? Sometimes fans can be dodgy but still spin, albeit slowly or inconsistently. Bad bearings or motor issues can cause such erratic behavior.
Task Manager Check:
This is more of an indirect method, but it’s worth a look. Fire up Task Manager (Ctrl+Shift+Esc), go to the Performance tab, and check the CPU usage. High CPU usage might indicate background tasks are keeping your CPU busy, causing it to heat up. You can then move on to inspect the Processes tab to pin down any culprits. Terminating unnecessary processes might reduce the load and hence the heat.
Photonic Thermal Imaging:
Okay, so this might be a bit James Bond, but thermal cameras can be super nifty. If you have access to one (or can use a borrowing service), you can get live thermal readings of your CPU and fan area. This will visualize hot spots, giving clues whether the fan is indeed lacking. Some higher-end smartphones also support thermal imaging with the right attachments.
Voltage and Power States:
If your motherboard supports it, software like HWinfo can show more than just speeds; it can also show CPU voltage and power states (C-states). Sometimes, the issue isn’t with the fan, but with the power delivery to the CPU. If the CPU isn’t cycling down to low power states when idle, it could be heating unnecessarily. Checking the voltages under load and idle conditions can be insightful.
Electrical Tape Trick:
Want a quick diagnostic hack? A strip of brightly colored electrical tape can be used as a visual speed check! Attach a small piece to a fan blade (offline, obviously) and watch it spin when you boot up. The movement should be pretty consistent and smooth. If you notice any hiccups or slight stops, might be a mechanical or electrical issue with the fan.
Cross-Referencing Software Data:
Instead of sticking to one software, cross-check using a few. What you see in SpeedFan, check it against HWMonitor, and also use something like Open Hardware Monitor. Sometimes, a single software might misinterpret data due to compatibility issues. Double or triple-checking ensures you get the correct readout.
Motherboard BIOS Update:
This one’s a little tech-jargony, but sometimes, BIOS updates released by your motherboard manufacturer include fixes for hardware monitoring and fan control. Check if there’s any update available for your specific board. Just be cautious with BIOS updates; they can be risky if done incorrectly.
Physical Inspection Routine:
Dusting’s been mentioned, but go further: reseat the CPU cooler. Sometimes thermal paste can degrade or be misapplied. A reapplication of high-quality thermal paste (like Arctic Silver 5 or Noctua NT-H1) might improve thermal conductivity. While you’re at it, make sure the mounting pressure of the cooler is even - uneven pressure can cause poor heat dissipation.
Fan Header Swap Test:
If you have multiple fans and fan headers on your motherboard, try swapping the CPU fan connector to another header. This will help rule out if it’s a bad header on the motherboard itself. Just renaming the headers in BIOS/UEFI might be necessary afterward for clarity.
Check for Fan Curve Adjustments:
Sometimes, users set custom fan curves in BIOS or thru motherboard software which are less aggressive. Making sure your fan curve is set to ramp up appropriately with increasing temps can drastically lower peak temps.
Power Supply Impacts:
Lastly, evaluate your PSU. A failing power supply can cause inadequacies in power delivery to CPU and fan headers. If possible, swap in a known good PSU to see if the issue persists.
These steps should give you a deeper look into the actual cause of your overheating woes. The key is a balance of physical inspection and data monitoring.
Honestly, this all sounds like overkill. You don’t need thermal cameras or electrical tape tricks to figure out your fan speed. Just check your BIOS and if you’re feeling adventurous, use HWMonitor or SpeedFan. Those apps are more than enough for 99% of users.
SpeedFan does give you control over the speeds, but it’s kinda janky and looks like it’s from the 90s. Not a fan (pun intended) of relying on outdated interfaces. HWMonitor is okay but limited to just showing you stats. You need something easy to use? Try the software from your motherboard manufacturer. ASUS AI Suite or MSI Dragon Center are integrated better and tailored for your hardware.
Honestly, fiddling with fan curves and BIOS updates can cause more problems if you don’t know what you’re doing. Instead, just keep it simple. Dust the rig, check the connectors, and if all else fails, cheap fans are easy to replace. No need to involve James Bond gadgetry here.
