At what temperature does a CPU get too hot?
My CPU seems to be running hotter than usual and it’s affecting my computer’s performance. I noticed this started happening after I installed a new game. Can someone please tell me what temperature range is considered too hot for a CPU, and what should I do if it exceeds that range?
Running a CPU too hot can significantly affect performance and longevity. CPUs typically have different thermal thresholds based on the manufacturer and model, but as a general rule of thumb, most modern CPUs shouldn’t run above 80-85ºC (176-185ºF) under load. Ideal operating temperatures usually hover around 40-50ºC (104-122ºF) during idle and shouldn’t exceed 70-75ºC (158-167ºF) under moderate workloads. Hitting 90-100ºC (194-212ºF) is dangerous and can cause thermal throttling or even permanent damage.
Now, since you mentioned that the issue started after installing a new game, it’s worth considering that games are demanding applications that can heavily tax your CPU, causing higher temperatures. Let’s go through a few steps to diagnose and potentially fix the overheating issue.
  1. Thermal Monitoring: First, use monitoring software like HWMonitor, Core Temp, or even software provided by your motherboard manufacturer to keep an eye on your CPU temperatures. This can confirm if the CPU is indeed overheating.
  2. Check Airflow: Make sure your computer case has adequate ventilation. This means clearing out any dust and ensuring that fans are unobstructed. Dust clogging can significantly affect cooling performance. Clean the system with compressed air, especially around the CPU cooler.
  3. Reapply Thermal Paste: If your CPU cooler is old or was recently installed (or re-installed), the thermal paste might not be applied properly. The thermal paste helps transfer heat from the CPU to the heatsink; if it’s dried out or improperly applied, it can hinder performance. Remove the old thermal paste with isopropyl alcohol, then apply a rice-sized drop of new thermal paste in the center of the CPU before securing the cooler.
  4. Upgrade Cooling Solution: Stock coolers are often insufficient for heavy gaming or overclocking. If your CPU is running consistently hot despite cleaning and reapplying thermal paste, consider upgrading to a more effective aftermarket cooler. Options include air coolers from brands like Noctua or be quiet! or even all-in-one (AIO) liquid coolers from Corsair or NZXT.
  5. Check Fan Curves: Sometimes, fan speeds aren’t adequately tuned for intensive workloads. You can adjust this in your BIOS/UEFI or through software like MSI Afterburner or SpeedFan. Set the fan curves so that fans ramp up faster as temperatures increase.
  6. Ambient Temperature: Room temperature also plays a role. If your room is particularly hot, it will affect your PC’s cooling efficiency. Make sure your setup is in a cool environment, and avoid placing your PC in enclosed spaces where heat can accumulate.
  7. Undervolting: For more advanced users, undervolting can help reduce the heat output of the CPU. This involves lowering the voltage supplied to the CPU, typically done through BIOS settings or specific software tools. However, this should be approached with care, as improper settings can lead to system instability.
  8. Hardware Limitations: Keep in mind that an older or less powerful CPU paired with a high-end game may simply be hitting its performance limits. Ensure that your hardware is up to the task of running the new game. Check the game’s system requirements and compare them to your current setup.
  9. Power Supply: Sometimes, issues can arise from an underpowered or failing PSU. While rare, insufficient power delivery can cause components to overheat due to inefficiencies. If you suspect your PSU, monitor the voltages using the aforementioned tools or consider having it checked by a professional.
If after all these steps your CPU continues to overheat, it may be beneficial to look into long-term solutions such as better case management or even a custom cooling setup. For extreme cases, a full custom water-cooling loop might be necessary, though this involves more investment and technical know-how.
In summary, the optimal range is to keep your CPU below 80-85ºC during heavy load while ensuring that during idle or medium usage, it stays within the 40-70ºC range. Regular maintenance and potentially upgrading your cooling solutions could resolve the issue, ensuring better performance and longevity of your CPU.
Hey, what @byteguru mentioned covers a lot of ground. However, there’s always more than one way to skin a cat. Here’s a few other angles to think about:
  1. Undervolt & Underclock: Unlike overclocking, which aims to boost performance, undervolting and underclocking your CPU can lead to cooler operation without a significant performance drop, especially if your workload is primarily gaming and general use. Tools like Intel XTU (for Intel CPUs) or Ryzen Master (for AMD CPUs) can help you tweak settings.
  2. Fan Positioning: Often overlooked, the positioning of intake and exhaust fans can impact thermal performance. Ensure you have a balanced airflow setup—typically, as many intake fans as exhaust fans, or slightly more intake to keep positive pressure and reduce dust buildup.
  3. Dust Filtration: If your PC is in a dust-prone environment, consider installing dust filters on the intake fans. These can be aftermarket additions if your case doesn’t come with them. Remember, though, filters need to be cleaned regularly as well.
  4. Room Air Circulation: Position your PC in a way that optimizes room airflow. Having it too close to walls or inside a desk cabinet limits fresh air supply and traps heat. A small room fan directed towards your PC case can sometimes make a surprising difference.
  5. Bigger Case: For those considering an upgrade, a larger case can offer better airflow options. More spacious cases generally support more and larger fans, and the increased volume allows for better dissipation of the internal heat.
  6. Liquid Metal: Thermal paste is a common solution, but have you ever considered using liquid metal? It offers superior heat transfer but requires careful application and maintenance due to its electrically conductive nature. Some brands like Conductonaut are quite popular in the enthusiast community.
  7. GPU Heat: Sometimes, the issue isn’t entirely the CPU. Your GPU, especially in newer games, could be adding to the overall heat inside the case. If your GPU runs particularly hot, it might be worth investigating cooling options for that as well.
  8. BIOS/UEFI Settings: Modern motherboards have advanced fan control options. Sometimes, simply updating your BIOS/UEFI can improve thermal management. Take a look in your BIOS/UEFI’s fan control settings and fine-tune from there.
Lastly, keep an eye on the software side – closing background apps and services that aren’t necessary can reduce load and, in extension, the thermal stress on your CPU. Not all performance issues are heat-related, so it’s beneficial to perform a thorough checkup on the software front as well.
While Byteguru’s advice is solid, I think some might be hesitant to jump straight to hardware changes. Subtle tweaks and less intrusive solutions can be equally effective and less daunting for beginners. Remember, your PC is a system of interdependent parts, and sometimes the solution lies in seeing the bigger picture rather than focusing only on the CPU temperature.
You guys are overthinking this. Seriously, 80-85ºC might be too conservative. Modern CPUs can handle up to 100ºC before throttling, though it’s not ideal. Worrying too much about 80-85ºC is overkill unless you’re experiencing sustained temps causing performance drops.
Updating BIOS or fan curve settings isn’t always magic, folks. Manually setting fan curves can get tedious and you might not even notice a massive difference. Plus, messing with BIOS without knowing what you’re doing can break more than it fixes. If you’re considering reapplying thermal paste, skip the liquid metal unless you’re experienced—it’s risky, can short-circuit, and needs more maintenance than paste like Arctic Silver 5.
And let’s be real, not everyone needs a Noctua or an AIO cooler. Sometimes, it’s just bad airflow. Make sure your cables aren’t all over the place. Just tidy up a bit inside the case. Exhaust fans are more important than intake, so optimize that first.
Games are heavy on the CPU, but if it’s just one game causing spikes, it’s possibly poorly optimized. Check forums for people having similar issues with that game.
Honestly, undervolting sounds nice, but it’s more of a hassle with marginal gains. If you’re not an advanced user, just avoid it. Simple cleaning and ensuring good ventilation should be your first steps for sure. Spend extra on an aftermarket cooler only if you’ve exhausted the basic steps.
Oh, and ambient temperature? Yeah, sure, it matters. But just keeping the room reasonably cool should be fine. No need for extreme measures like setting up extra fans around your PC case. That’s just overdoing it.
